SteamVR setting 64hz instead of 90zh
Slowly getting things working, current struggle is that Steam VR insists that my refresh rate is 64hz even though it is set to 90hz in the PiTool.
Any idea how to fix that?
https://community.openmr.ai/t/pimax-not-detected-amd-5700-xt/21727/21?u=drwilken
First check in game what is true refresh rate.If 90 I woudnt bother…
If 64 then change values in pitool, 180 is buggy sometimes showing innacurate refresh rate.
Thanks. I’ll try switching to 64 and then back again. It’s definitely actually at 64, because Skyrim VR locks right to 64 fps when running.
Thank you! That was indeed the problem. Now that I know to read the display in the bottom left corner, not the reading in the popup menu, I’ll know what’s going on in the future.
