Prior to SteamVR being launched, verify there are no PiTool phantom OVR_Launchers still running and verify that there is nothing that failed to exit properly.
I did that of course. restart pc etc … everything does not help.
no matter what I do.
I’m starting a game with Pitool or Experience. when I quit the game and Steamhome is loaded, the graphics are extremely jerky. The whole steamVR home causes graphic problems.
Is steamvr home something you want to use? I have disabled all the “headset home” applications since they started releasing them. Right click steamvr go into settings and disable the home apps and any overlay stuff you dont use or care about. Do the same in pitool.
The only thing i want to use in the new pimax experience is the IPD adjustment tool thing and its not available yet
It would seem that insuring users can correctly setup the ipd stuff would trump ui design. But maybe the majority of users dont have issues with the ipd. But how would they know if they dont have a tool that collects that data… or clear instructions written (BY THE COMPANY) about how to configure this stuff… Anyway… rant off
Your PE settings aren’t good for SteamVR Home (listed as SteamVR in PE profiles)
When you quit the game it loads into SteamVR Home (as expected) but keeps the settings you had for the game. If the settings are too high, then SteamVR Home freaks out.
