Hi! Am I the only one for whom the Desktop in the SteamVR dashboard is not working?
It just shows me an empty sceen since the new SteamVR update. Is there some way to remedy that issue?
Thanks
If dashboard can not be activated (nothing happened) then it is disabled in steamvr settings. Enable it.
If something happened, but actualy does not work as intended, then go to steam, search for steamvr, right click on it, check file integrity.
If that does not help, same as above, but activate steamvr beta. Later you can revert back, as beta is flickering as discoteque.
