Many changes in one week, I like the new interface, and I have better performance and compatibility with Pimax and Index;
SteamVR Beta Updated - 1.9.9
SteamVR - Jeremy Bot
The SteamVR beta has been updated with the following changes.
If you encounter issues with this update, please post in the SteamVR Bug Report forum. If possible, please include a system report to aid in tracking down your issue. Replies to this post are not tracked for bug reporting purposes. Please use the forum linked above to report issues.
SteamVR
- Fix possible crash/corrupted icon when loading dashboard overlay images (including VIVEPORT)
SteamVR Desktop View
- Fix hang when querying overlay visibility.
Share:
10 DEC
SteamVR Beta Updated - 1.9.8
SteamVR - freemancw
SteamVR Settings
Fixed regression in range of Index Column correction adjustment
Added advanced setting to control desktop scale.
Added advanced setting to control dashboard distance (experimental).
Added ability to view and toggle which overlay apps automatically launch with SteamVR.
Removed sidebar link to Audio page on Linux, since it was for Windows-only audio settings.
Background list updates automatically when subscribing/unsubscribing from backgrounds in Steam client.
Miscellaneous style tweaks.
SteamVR Input
Fixed community bindings not appearing in the binding list.
Requests from editors (Unity, UE) to pop up the binding interface to pop up the full interface and not the new settings panel. Note that the full binding interface is available as a button in the new settings controller tab when “advanced” controls are shown.
SteamVR Dashboard
SteamVR Audio
- Fixed audio static when mirroring to an output with a different sample rate than the source.
Share:
7 DEC
SteamVR Beta Updated - 1.9.7
SteamVR Settings Beta
Most settings have been ported to a new user interface
Most settings now available on both the desktop, and in-headset.
The new SteamVR settings are still a work in progress.
SteamVR
Improved audio mirroring latency and fixed some cases where the mirror could accumulate a large delay.
Skip “Advanced Supersampling Filtering” for systems which use their own compositor (e.g. WMR, Oculus). This should fix blurriness reported by WMR users.
Fixed some memory leaks when VR_Init is called repeatedly in long-running applications.
All windows now group together under one icon in the Windows taskbar.
SteamVR Dashboard
Added haptic bumps with moving on or off of buttons on the dashboard controls.
Added support for haptic bumps when moving around on the keyboard.
Minor appearance tweaks.
Fixed a variety of crashes in vrdashboard.exe
SteamVR Input
For games using legacy input: When fetching default bindings, prefer partner site explicit defaults instead of generic legacy defaults
When switching bindings, SteamVR now records the previously selected binding in a setting.
Action Sets with a higher priority will now correctly override sets with a lower priority.
Recent games list in top level controller configuration menu now shows most recent game instead of starting with second most recent game.
Index HMD
Max brightness extended to 140
Framerate can be changed without restarting (requires NVIDIA driver version 441, or higher)
Requires firmware update
Share:
5 DEC
SteamVR Beta Updated - 1.9.6
SteamVR - aaron.leiby
SteamVR:
- Fix rare case where a helper process would crash on startup, making some UI unavailable.
