Has anyone figured out how to make the vive/steamVR 2.0 base stations go to sleep and for the bluetooth to work with the pimax 5k+?
They stay on forever as it always has, unless i have a valve index or Vive connected which can connect via bluetooth. Pimax doesnt seem to have a bluetooth signal with the base stations and therefore can’t tell steamVR to put the base stations to sleep.
I use the Renasas GATTBrowser App as proposed by a forum member.
Its a bit nerdy, but I like it.
You need to find the LHs then a specific entry and write 0x00 - >off or 0x01 - >on.
There is also a tool in work by another forum member that works on the pc.
I am not at my pc room so I don’t have them here, but basically I turn them in standby with the 0x00, then the led turns blue and the motor stops. 0x01 turns them on, led flashes, turns green and motor spins up
We had a thread about it a while ago, I knew about the programming going on in the community but the app is a great workaround. I am also happy since I find the LH quite noise to keep running all the time.
