Are you guys able to start Steam VR home since the last update? No matter what I try, it just doesn’t start to anymore.
Thanks for your help!
I had that problem, are you using the beta? I reverted to the main release and it worked
I’m using beta and Steamvr starts. But when I start it from Pitool, Home is reset (no more workshop, tutorial starts…). When I start Steamvr from Steam, my saves are back. It’s like there are 2 instances…
Had same issue but with Beta, using Main now and all good atm.
weirdly enough, switching to beta from main solved my problem
I haven’t seen the issue at all. Beta all the way…
