Hello, have someone tested the 5K or 8K with the vorpx app in some games? Some issues with its fov and wider resolution?
This is from VoodooDE’s review:
01:59:32,220 --> 01:59:37,960
Some people asked me if I can try VorpX games on the Pimax headsets.
765
01:59:38,960 --> 01:59:42,260
I did that and tried Kingdom Come Deliverance for example.
766
01:59:43,460 --> 01:59:46,080
What should I say? NO!
767
01:59:46,640 --> 01:59:51,480
You cant really play VorpX games on the Pimax headsets, at least for now.
768
01:59:52,000 --> 01:59:57,140
It has no problem with picture or with streching.
769
01:59:57,420 --> 02:00:02,860
However the performance is so bad and it stutters really hard!
770
02:00:03,100 --> 02:00:07,020
In every possible resolution.
771
02:00:08,560 --> 02:00:13,320
It runs much better on the Vive Pro with same settings!
772
02:00:13,640 --> 02:00:17,940
Even on a very low resolution it doesnt work well.
773
02:00:18,920 --> 02:00:21,260
You only got half of the FPS!
774
02:00:21,540 --> 02:00:28,240
So I have to disappoint you if you are a fan of VorpX or normal PC games in VR.
775
02:00:29,720 --> 02:00:34,980
Perhaps you have to wait for a patch.
776
02:00:36,340 --> 02:00:40,260
For now just forget about it, its nearly unplayable.
