Some basic questions?
1- Will have Linux support soon?.
2- Spanish language support? // Or in the future?
3- Because it asks for a gtx 960 instead of a 970?
4- The 4k is real or a scaling?
5- You can upload more videos of the device ?
Some I can Answer
  1. As a fellow Linux User I’d like to see this as well. But at the moment Linux support is likely to come but not likely soon.
  2. Spanish Language support plan? @Pimax-Support @bacon
  3. Unsure of your question? If 960 works then 970 should be better.
  4. Display Panel Resolution is 4k. Headset accepts 1080p (low spec) or 1440p then uses Upscaler in headset to 4k.
  5. Lots of video reviews & such available on youtube.
