Hey
Just got pimax 5k+ and wow its amazing. In any caes my project cars 2 eyes are not matching, they are miles away from each other… how on earth do I fix it?
EDIT : elite dangerous - the same issue… eyes are miles apart :- (
Hey
Have tried Paralell Projection turned on? Restart Steamvr after enabling.
This needs updating but may help.
https://community.openmr.ai/t/faq-getting-started-5k-8k/9468/3?u=heliosurge
I was changing that option now and restarting HMD. now my HMD is in DFU mode as far as I can tell - pink led… I mean… how did that happen ?! I just clicked reprojection & restart steam/hmd…
What to do ? :- (
Elite Dangerous is broken too sigh.
Make sure you are not using application specific settings. Elite needs PP. After you select PP you need to restart SteamVR
I restarted PC and HMD become responsive again. But the blue led at front blinks and led up top is purple… not sure what to do with it.
Purple means Paralell Projection ls on
If you’re using an Nvidia 10*0 card, try to see if you can update its firmware using this tool:
NVIDIA Graphics Firmware Update Tool for DisplayPort 1.3 and 1.4 Displays.
@Heliosurge mentioned this a while back; I updated my card after which I found my Pimax 5K+ to be less finicky.
Oh in this case I’m all good!
I enabled reprojections and elite looks good. So I think all good. Thanks!
It. Is. EPICCCCCCCCCC
How do I mark topic as solved?
I can do that for you. Should I lock the thread too?
Yap solved thank you!
