In some games i see image in vr pimax 5k+ splitted, separated, so is impossible to play, (for example in Helblade seuna’s sacrifice) anyone know something about this problem? some solutions?
Have you tried enabling Parallell Projection?
Lol just replied to your other thread
yes but nothing the images rest separated, is normal? someone else have this problem?
Yes I think it is normal. Believe after you switch on Parallel Projections you have to restart for it to kick in.
Thankyou again for all ^^ i solved also this problem, i have just one question that i dont know i which category is postable, i ask you here for now, i see the image of pimax 5k+ is like flat, i try to explain better, i cen percept less feeling of deepness then other vr, there is some kind of settings to improve deepness perception? i dont know how to explain good, but is like the image is not really really deep at the center, a little bit flat and maybe distorted, you can understand what i mean?
If your using Pitool 121B or 129B try soft ipd offset. Starr witb -0.5 & +0.5 and see if it improves stereo effect.
ok thakyou, now i can feel a better deepness ^^ but still feel a little bit of distortion at the center of the screen, but i think is a lense problem right?
Difficult to say. One thought is one eye might be a bit fuzzy than the other as a trade off for hi fov headset. For me both eyes seem to have even focus. But I might be within an ideal ipd & ipd symetry. Or my brain might have essier focus adaptation.
My ipd is 67.1 according to ipd ap. It’s whst i use. I get eyestrain when using soft ipd
hmm no, i see at the center of the lens, an effect like distorsion that make flat objects at the center a little bit deformed, like at the center there is an hollow, i dont know how to say but if i look expecially a flat surface, like a wall, i see like someone give a punch on the center of the wall and make a depression/hollow, and this make a general perception like fake
Hmmm… Are ypu able to capture it in a pic through lens?
hmm no, i tryed but with my camera is impossible to see it, anyway i think is a distorsion by lenses, at the center is like image is a little bit pulled of, i dont feel disturbed about perimetral distorsions but at the center i dont like, i hope that is possible to resolve this problem
