1 - When I launch PVE for the first time at windows startup with “Start Pimax Vr Home” checked, the interactions work. But after it doesn’t work anymore after launching a game etc…
2 - When I launch PVE from PVRHome.exe for the first time at windows start with “Start Pimax Vr Home” unchecked, the interactions don’t work.
Résumé
Mono path[0] = ‘C:/Program Files/Pimax/PVRHome/PVRHome_Data/Managed’
Mono config path = ‘C:/Program Files/Pimax/PVRHome/MonoBleedingEdge/etc’
Initialize engine version: 2019.3.7f1 (6437fd74d35d)
[Subsystems] Discovering subsystems at path C:/Program Files/Pimax/PVRHome/PVRHome_Data/UnitySubsystems
GfxDevice: creating device client; threaded=1
Direct3D:
Version: Direct3D 11.0 [level 11.1]
Renderer: NVIDIA GeForce RTX 2080 Ti (ID=0x1e07)
Vendor:
VRAM: 11049 MB
Driver: 27.21.14.5206
Begin MonoManager ReloadAssembly
- Completed reload, in 1.252 seconds
D3D11 device created for Microsoft Media Foundation video decoding.
Initializing input.
Input initialized.
Initialized touch support.
UnloadTime: 6.899400 ms
ArgumentNullException: Value cannot be null.
Parameter name: shader
at (wrapper managed-to-native) UnityEngine.Material.CreateWithShader(UnityEngine.Material,UnityEngine.Shader)
at UnityEngine.Material…ctor (UnityEngine.Shader shader) [0x00008] in <73b499366e5241bda47e5da76897738b>:0
at LaserPointerController.Awake () [0x00166] in <455509d9559f47979df56a33210206d9>:0
(Filename: <73b499366e5241bda47e5da76897738b> Line: 0)
2020-08-28 12:19:15:686 :[Debug] Awake() Initialization started…
(Filename: C:\buildslave\unity\build\Runtime/Export/Debug/Debug.bindings.h Line: 35)
2020-08-28 12:19:15:692 :[Debug] User settings file found, now continuing…
2020-08-28 12:19:15:729 :[Debug] OK! New implemented arguments with values (due to new VRHome version) added to Config File. Settings saved to: C:/Users/Phoeniix/AppData/LocalLow/Pimax/PVRHome/userSettingsPVR.json
2020-08-28 12:19:15:733 :[Debug] Attempting to change UI Theme…
2020-08-28 12:19:15:735 :[Debug] Changing UI Theme…
2020-08-28 12:19:16:468 :[Debug] Default UI Theme selected…
2020-08-28 12:19:16:468 :[Debug] Changing view mode Basic/Advanced…
2020-08-28 12:19:16:468 :[Debug] View mode changed to Basic!
2020-08-28 12:19:16:470 :[Debug] Starting import of new VivePort games…
2020-08-28 12:19:16:470 :[Debug] VivePort import finished!
2020-08-28 12:19:16:471 :[Debug] Searching for SteamVR Installation…
2020-08-28 12:19:16:514 :[Debug] Steam install path found (64 bit Windows): C:\Program Files (x86)\Steam
2020-08-28 12:19:16:525 :[Debug] Searching for Oculus Home Installation…
2020-08-28 12:19:16:525 :[Debug] Oculus install path found (64 bit Windows): C:\Program Files\Oculus\
2020-08-28 12:19:16:525 :[Debug] Searching for VivePort Installation…
2020-08-28 12:19:16:525 :[Debug] Awake() Initialization finished!
2020-08-28 12:19:16:606 :[Debug] Listing all games in steam category…
2020-08-28 12:19:17:784 :[Debug] Start() Initialization begins…
2020-08-28 12:19:17:785 :[Debug] Checking if all games have profiles…
2020-08-28 12:19:17:794 :[Debug] Checking if all SteamVR/VivePort/Imported games have a SteamVR profile…
2020-08-28 12:19:17:808 :[Debug] Waiting 2 seconds to retrieve all values before continuing…
2020-08-28 12:19:17:812 :[PVR-Unity] Starting
Setting up 8 worker threads for Enlighten.
Thread → id: 3bbc → priority: 1
Thread → id: 376c → priority: 1
Thread → id: 3770 → priority: 1
Thread → id: 3ee4 → priority: 1
Thread → id: 3764 → priority: 1
Thread → id: 3ec8 → priority: 1
Thread → id: 3ef0 → priority: 1
Thread → id: 3eb0 → priority: 1
2020-08-28 12:19:19:915 :[Debug] PiTool Connection: Values sent to PiTool…Awaiting response…
2020-08-28 12:19:19:915 :[Debug] Values sent to PiTool: {
“message”:0
2020-08-28 12:19:20:913 :[Debug] Loading all Main-Settings + Quick-Settings…
2020-08-28 12:19:20:914 :[Debug] Changing view mode Basic/Advanced…
2020-08-28 12:19:20:914 :[Debug] View mode changed to Basic!
2020-08-28 12:19:20:929 :[Debug] All Main-Settings + Quick-Settings loaded!
2020-08-28 12:19:20:986 :[Debug] Start() Initialization finished!
2020-08-28 12:19:21:034 :Leap Service not connected; attempting to reconnect for try 1/5…
2020-08-28 12:19:23:549 :Leap Service not connected; attempting to reconnect for try 2/5…
2020-08-28 12:19:24:934 :[Debug] PiTool Connection: PiTool Responded and Settings are Applied!
2020-08-28 12:19:24:934 :[Debug] PiTool responded! Active settings: {
“backBrightness”: 4,
“blackEnable”: false,
“brightnessleft”: 0,
“brightnessleft_B”: 0,
“brightnessleft_G”: 0,
“brightnessleft_R”: 0,
“brightnessright”: 0,
“brightnessright_B”: 0,
“brightnessright_G”: 0,
“brightnessright_R”: 0,
“colorChannelValue”: 0,
“comboFov1”: 1,
“comparapro”: false,
“contrastleft”: 0,
“contrastleft_B”: 0,
“contrastleft_G”: 0,
“contrastleft_R”: 0,
“contrastright”: 0,
“contrastright_B”: 0,
“contrastright_G”: 0,
“contrastright_R”: 0,
“currentRefreshIndex”: 2,
“displayName”: “Pimax 5K Plus”,
“displayquality”: 1.25,
“foveated”: true,
“foveatedcom”: -1,
“headTracked”: true,
“hiddenarea”: true,
“homeSupport”: true,
“ipd”: 0,
“refreshValues”: “110 90 72 64”,
“smartfill”: false,
“startalone”: false,
“suppervivegame”: false,
“supportFoveated”: true,
“title”: “Common Setting”,
“verticalOffsetLeft”: 0,
“verticalOffsetRight”: 0
2020-08-28 12:19:24:940 :[Debug] Updating SysInfo values…
2020-08-28 12:19:24:941 :[Debug] Initializing HMD values from PiTool…
2020-08-28 12:19:24:942 :[Debug] Init HMD values done!
2020-08-28 12:19:24:944 :[Debug] Active Advanced Image Adjustments loaded from active profile
2020-08-28 12:19:26:062 :Leap Service not connected; attempting to reconnect for try 3/5…
2020-08-28 12:19:28:575 :Leap Service not connected; attempting to reconnect for try 4/5…
2020-08-28 12:19:31:089 :Leap Service not connected; attempting to reconnect for try 5/5…
2020-08-28 12:20:58:091 :[Debug] Saving Quick-Settings…
2020-08-28 12:20:58:095 :[Debug] OK! Profile saved. Quick-Settings saved to: C:\Users\Phoeniix\AppData\Roaming\PiTool\manifest\PiTool\Common Setting.json
2020-08-28 12:20:58:924 :[Debug] Applying Quick-Settings…
2020-08-28 12:20:58:924 :[Debug] PiTool Connection: Values sent to PiTool…Awaiting response…
2020-08-28 12:20:58:924 :[Debug] Values sent to PiTool: {
“parameter”:{
“blacklevel”: 0,
“brightnessleft”: 0.0,
“brightnessleft_B”: 0.0,
“brightnessleft_G”: 0.0,
“brightnessleft_R”: 0.0,
“brightnessright”: 0.0,
“brightnessright_B”: 0.0,
“brightnessright_G”: 0.0,
“brightnessright_R”: 0.0,
“comboFov1”: 1,
“comparapro”: true,
“contrastleft”: 0.0,
“contrastleft_B”: 0.0,
“contrastleft_G”: 0.0,
“contrastleft_R”: 0.0,
“contrastright”: 0.0,
“contrastright_B”: 0.0,
“contrastright_G”: 0.0,
“contrastright_R”: 0.0,
“foveated”: false,
“foveatedcom”: -1,
“hiddenarea”: true,
“smartfill”: false,
2020-08-28 12:20:58:925 :[Debug] Saving Custom UI Settings…
2020-08-28 12:20:58:928 :[Debug] OK! Customized user settings saved. Settings saved to: C:/Users/Phoeniix/AppData/LocalLow/Pimax/PVRHome/userSettingsPVR.json
2020-08-28 12:20:58:928 :[Debug] Quick-Settings applied!
2020-08-28 12:20:58:935 :[Debug] PiTool Connection: PiTool Responded and Settings are Applied!
2020-08-28 12:20:58:935 :[Debug] PiTool responded! Active settings: {
“comboFov1”: 1,
“comparapro”: true,
“contrastleft”: 0,
“contrastright”: 0,
“foveated”: true,
“foveatedcom”: -1,
“hiddenarea”: true,
“ipd”: 0,
“smartfill”: false,
2020-08-28 12:20:58:937 :[Debug] Updating SysInfo values…
2020-08-28 12:20:58:939 :[Debug] Updating/refreshing Main-Settings…
2020-08-28 12:20:58:940 :[Debug] Main-Settings updated!
2020-08-28 12:20:58:941 :[Debug] Updating/Refreshing Quick-Settings…
2020-08-28 12:20:58:942 :[Debug] Quick-Settings updated!
2020-08-28 12:20:58:942 :[Debug] Initializing HMD values from PiTool…
2020-08-28 12:20:58:942 :[Debug] Init HMD values done!
2020-08-28 12:20:58:942 :[Debug] Active Advanced Image Adjustments loaded from active profile
Résumé
Direct3D:
Vendor:
VRAM: 11049 MB
- Completed reload, in 0.065 seconds
Initializing input.
Input initialized.
UnloadTime: 0.425800 ms
2020-08-28 12:28:19:775 :[Debug] Awake() Initialization started…
2020-08-28 12:28:19:778 :[Debug] User settings file found, now continuing…
2020-08-28 12:28:19:790 :[Debug] OK! New implemented arguments with values (due to new VRHome version) added to Config File. Settings saved to: C:/Users/Phoeniix/AppData/LocalLow/Pimax/PVRHome/userSettingsPVR.json
2020-08-28 12:28:19:792 :[Debug] Attempting to change UI Theme…
2020-08-28 12:28:19:793 :[Debug] Changing UI Theme…
2020-08-28 12:28:19:823 :[Debug] Default UI Theme selected…
2020-08-28 12:28:19:824 :[Debug] Changing view mode Basic/Advanced…
2020-08-28 12:28:19:824 :[Debug] View mode changed to Basic!
2020-08-28 12:28:19:826 :[Debug] Starting import of new VivePort games…
2020-08-28 12:28:19:826 :[Debug] VivePort import finished!
2020-08-28 12:28:19:826 :[Debug] Searching for SteamVR Installation…
2020-08-28 12:28:19:828 :[Debug] Steam install path found (64 bit Windows): C:\Program Files (x86)\Steam
2020-08-28 12:28:19:829 :[Debug] Searching for Oculus Home Installation…
2020-08-28 12:28:19:829 :[Debug] Oculus install path found (64 bit Windows): C:\Program Files\Oculus\
2020-08-28 12:28:19:829 :[Debug] Searching for VivePort Installation…
2020-08-28 12:28:19:829 :[Debug] Awake() Initialization finished!
2020-08-28 12:28:19:841 :[Debug] Listing all games in steam category…
2020-08-28 12:28:19:880 :[Debug] NOTE: Game: TheFirstClass VR 第一课 VR had non-allowed characters in title name. Title has been fixed and saved to game JSON: C:\Users\Phoeniix\AppData\Roaming\PiTool\manifest\steam.app.630020.json
2020-08-28 12:28:20:497 :[Debug] Start() Initialization begins…
2020-08-28 12:28:20:498 :[Debug] Checking if all games have profiles…
2020-08-28 12:28:20:507 :[Debug] Checking if all SteamVR/VivePort/Imported games have a SteamVR profile…
2020-08-28 12:28:20:516 :[Debug] Waiting 2 seconds to retrieve all values before continuing…
2020-08-28 12:28:20:518 :[PVR-Unity] Starting
Thread → id: 48b4 → priority: 1
Thread → id: 1d84 → priority: 1
Thread → id: 30e0 → priority: 1
Thread → id: 3414 → priority: 1
Thread → id: 2b80 → priority: 1
Thread → id: 3e0c → priority: 1
Thread → id: 4ed8 → priority: 1
Thread → id: 351c → priority: 1
2020-08-28 12:28:22:141 :[Debug] PiTool Connection: Values sent to PiTool…Awaiting response…
2020-08-28 12:28:22:141 :[Debug] Values sent to PiTool: {
“message”:0
2020-08-28 12:28:22:141 :[Debug] PiTool Connection: PiTool Responded and Settings are Applied!
2020-08-28 12:28:22:141 :[Debug] PiTool responded! Active settings: {
“comboFov1”: 1,
“comparapro”: true,
“contrastleft”: 0,
“contrastright”: 0,
“foveated”: true,
“foveatedcom”: -1,
“hiddenarea”: true,
“ipd”: 0,
“smartfill”: false,
2020-08-28 12:28:22:152 :[Debug] Updating SysInfo values…
2020-08-28 12:28:22:153 :[Debug] Initializing HMD values from PiTool…
2020-08-28 12:28:22:154 :[Debug] Init HMD values done!
2020-08-28 12:28:22:155 :[Debug] Active Advanced Image Adjustments loaded from active profile
2020-08-28 12:28:23:140 :[Debug] Loading all Main-Settings + Quick-Settings…
2020-08-28 12:28:23:141 :[Debug] Changing view mode Basic/Advanced…
2020-08-28 12:28:23:141 :[Debug] View mode changed to Basic!
2020-08-28 12:28:23:146 :[Debug] All Main-Settings + Quick-Settings loaded!
2020-08-28 12:28:23:181 :[Debug] Start() Initialization finished!
2020-08-28 12:28:23:235 :Leap Service not connected; attempting to reconnect for try 1/5…
2020-08-28 12:28:25:748 :Leap Service not connected; attempting to reconnect for try 2/5…
2020-08-28 12:28:28:262 :Leap Service not connected; attempting to reconnect for try 3/5…
2020-08-28 12:28:30:776 :Leap Service not connected; attempting to reconnect for try 4/5…
