RMA unit #2 arrived after 4 weeks of chasing. First unit arrived on the 15/12/2018 and have bad light leakage on the top and bottom of screen. Eagerly await a replacement, but unfortunately the replacement unit also had fault. Fault #no.1 Screen is swamp with flickering dots.
#fault no2:
Light leakage on the far right side of right screen with Normal & large FOV option in Pitool. .95
Methods I have tried to resolve the problems by trying on another VR ready PC, restarting Pi service, disconnecting the HMD, rolling back Graphic card driver etc. Nothing seems to help.
My PC specs: Intel i7 8800K(overcloced to 4.8MhZ), Zotac 1080 Extreme AMP, 16gb 3000Mhz RAM, Windows10 Pro.
Omfg! I love the Pimax community!!! I follow @spamenigma and @McErono advise. Got everything sorted!
First I try to re-seat the cable but that didn’t work. Then I remove the entire cable and replace with the old cable and bingo! It solved the problem! LOVE YOU ALL!
@Matthew.Xu, please take note, tell the QC team to check the cables before sending the units out.
