No idea what went wrong here.
Steps:
- I upgraded from 0.22 to 0.24. Everything still worked, games were shown
- Did some A/B comparison between 8kX 114 Hz upscale mode and 5k+ 144 Hz mode. For that I switched from 8kX to 5k+ first.
- Initially all still worked well.
- Then at some point Steam crashed (think it happened when I tried to exit into PE again)
- after everything was restarted again I didn’t see any games in the Steam tab anymore. When starting Steam Home (by switching on the controllers after the headset) I can still see all my Steam games. The ViveHome games are still visible in PE.
- Switched then back to the 8kX - no change, the games are still invisible.
Regarding log files:
- userSettingsPVR.json is empty (0 bytes)
- Player.log shows one perhaps noteworthy thing (haven’t checked it when it still worked, so cannot compare):
2020-08-27 22:34:13:904 :[Debug] User settings file found, now continuing…
(Filename: C:\buildslave\unity\build\Runtime/Export/Debug/Debug.bindings.h Line: 35)
NullReferenceException: Object reference not set to an instance of an object
at optionValuesHandler.Awake () [0x00249] in <455509d9559f47979df56a33210206d9>:0
(Filename: <455509d9559f47979df56a33210206d9> Line: 0)
The manifest folder contains various json files that seem to correspond to my Steam games on first sight.
Is there anything particular I should look for?
