so I got this $70 coupon code from pimax for the 10m cable I ordered during kickstarter, pimax had sent me a coupon for it due to not being able to produce the product…how do I use that coupon? I tried to punch the code in the “promo code” when ordering accessory but it said invalid code. I’ve try to reach back out on the ticket but it’s been 2 weeks and pimax still haven’t reply
Kontakt Asales as you did - you Need a new Coupon, they changed the System and will update it.
Also you should do that with a ticket (=support) as you did.
When you get the new Code (1-3 days) then go Shopping and the new Code will work.
they are catching up on tickets - so a small reminder or a PM to asales and it should get rolling.
I was already going for the eye tracker and maybe hand tracker, so.
And as much as I’m dissatisfied with Pimax and the reinvention of the meaning of delays, I am still a fan and am still hoping they can get past all this, simply because their product is fun enough but also because I knew how they operated from before the Kickstarter campaign. I’ll always root for the underdog.
