It was mentioned that the Artisan would have Pimax 4k like headphones, but this isn’t mentioned on the store page. Does it have headphones?
With Nolo yes without no as i understod it.
The idea seems to be either upgrade from Vive/Vive Pro (where You have controllers + basestations) or get it with it’s own tracking/controller solution → Nolo. It’s meant as an “entry level” product into the Pimax eco system (as it still supports all the modules - hand tracking, eye tracking etc.).
Will get someone to answer your question. Thanks.
