Skymap resources
Some free Skymap resources:
https://render.otoy.com/vr_gallery.php
The OTOY skymaps are stereoscopic. At least, I think that’s the term. My favorite is “The Dragon’s Nest”. I couldn’t find a license description but it’s a simple download. If nothing else, download the ones that you like for your personal use!
The ones on the github are ones that I created using Google Streetmaps. Please feel free to use/distribute any or all of them, as far as I’m concerned.
WOW thats freakin awesome, thanks a lot man - this will be golden for PE!! :slight_smile:
The format on the Github ones were altered for VRToolbox but I’ve got the originals, in case you run into any problems. Github is dds, I’ve also got jpg’s. Also, I believe that I had to reduce the quality to upload them. The originals seem to run from 5Mb-25Mb. As I say, let me know if you want to pursue them.
Edit: in particular, you need to test the mirroring. For VRToolbox, I had to invert them. I believe that you would need the same but I can probably invert the originals without sacrificing the quality, if needed.
(Welcome to Dr.Strange’s Mirror Dimension :crazy_face: )
Thanks! Size is really not a huge problem, as long as its somewhere between 10-30mb each. Actually, many of the sky/cloud skyboxes that are included in PE were 8K resolution and each was 40-60Mb in size. I resized the textures to 4K and 10-25Mb each.
