Anyone else is having the same issue? I uninstalled all Pimax software, disconnected HMD and tried to install again - same problem.
The headset (Pimax 5K+ appears as being detected, but when I put it on I only see the Pimax logo, not the volcano/moon/mountain scene, and SteamVR is likewise unable to establish connection to the headset.
the steam vr integration is done by this
C:\Program Files\Pimax\SteamVRSupport\drivers\aapvr\bin\win64\driver_aapvr.dll
check if it is present, there might be problem with your virus protection software preventing this part to be installed, we have seen this earlier as the microsoft protection had a false positive, pimax installed needed to be whitelisted and later it was automatically whitelisted be MS
edit: to check the validity of the installer, its signed and you can compare the cert with older versions of the installer
Summon Taskmanager Kill all Pi related named processes. Might be an idea to exit steam & try install again. I would reccommend maybe re downloading Pitool as there maybe an issue caused by download.
Umm. Based on the title of this thread… People are assuming that the issue is that pitool app is running during install? But that may not be the case. If another app is running on the machine during startup that can impact pitool installation then if will always fail to install and give that exact message!
Have you tried booting to safe mode with networking and install pitool there… Then see if you get prompted that there is an app stopping pitool installation?
if you want to test a little more, it is possible to unpack the pimax installer with innounp (Inno Setup Unpacker) Version 0.48
you will get 6 additional setup exe files and i guess one of them might fail
PiServiceSetup.exe
pvr_home_setup.exe
pvr_oc_support_setup.exe
pvr_runtime_setup.exe
pvr_steamvr_driver_setup.exe
SetupFont.exe (the one has i file date from 1/2019, so it did not change and will not be the source of the problem)
but it will probably not solve your problem, just a little more information whats going on
