It is stuck searching at that is it. Screen works and everything seems to be fine except that.
GTX 970
Core i5
Windows 10
Piplay v1.1.87 release
Thanks for your time.
EDIT: I used my old laptop and it worked fine. I am pretty sure that it’s not working now because I only have one HDMI out and I am using an HDMI splitter. Is there an update or something where I can trick windows into recognizing another display even though there isn’t one?
Hello! I managed to fix the issue on my own. It works fine but the display doesn’t show. To get it showing I had to connect it to SteamVR and then it was golden.
