The image disappears from the screens shortly after I connect the headset.
PiTool reports the headset as working OK, but the LED on the headset is red, and there is no image.
The image comes back, if I unplug the DP connector and plug it in again, but after a moment it dissappears again.
Here’s a video of the problem:
I am connecting the headset using a USB C - DP adapter on my laptop.
The problem started after I attempted a clean install of the video drivers.
I was following this guide:
I have tried to update PiTool and Nvidia drivers, but the problem has not gone away.
Pimax supprot is trying to help me, but they don’t seem to have a quick fix for this.
If there is no easy solution I might just reinstall Windows and maybe see if some older versions of PiTool and Nvidia drivers work better.
