Is the same anti-blue-light-filter used as in the Pimax 4K which makes the colors and contrast much darker?? I hated it. Look at this: dark Pimax - Album on Imgur
They have confirmed it is not the same blue light system as the 4K. They have improved it
Plus the 4k used shudder glass as its custom low persistance. Shudder glasses in 3d dull the picture. The new panels are a clpl (Custom Low Persistance Liquid) lcd panel (no shudder glass)
We have removed this filter in V2 and V3, and plan to remove it in the MP version, although reserved the function in system design.
OK, I believe you but the pictures shows the contrary. We will see.
