So, i recently got a 5k super,
i had several issue to get it stable as there was different problem from different part
and wanted to share my experiences and solutions to my issues
display port not connected ( if you have more than one gpu - in my case a nvidia GT710 and the RX6800XT )
— i have 2 gpu in my machine, disable the one you are not using in windows devices manager and reboot -
freezing due cpu issue
—workaround in bios/uefi disable fTPM -
lag/stuttering
— disable rgb (aura off in uefi/bios) -
various crash related to usb and/or power management
— disable ‘legacy usb’ xhci hand-off in uefi/bios
— disable power management of usb in windows OS
— in steamvr put to never to shutdown controller , no to “shutdown controller when leaving steamvr” and never to "
quit steamvr"
— in steamvr audio set to “manual” and chose the one you use ( usb audio in my case for the kdmas) same for microphone -
Also sometime i had tracking issues, point of view stuck on the floor or point of view stuck in the virtual basestation
—rebooting countless time after countless room calibration ( in pitools then steamvr) NEVER did the trick …
—controllers always on BEFORE starting steamvr
—what worked like a charm is :
--------- unplug hmd ( dp and USBs)
--------- open windows devices manager → menu “display " show hidden devices
--------- in the device list, all” greyed out" device are not connected, just uninstall them
--------- reboot, replug
--------- room calibration
enjoy
pitool 1.0.1.277
firmware 2.1.255.273
p.s: pi_server always try to load nvapi ( Failed to init nvapi with error=0x-6 even if not installed)
perhaps is the source of device not working when the 2 gpu are enabled ( i have an amd and nv )
not a real problem as i use the 2 gpu only when i boot my multiseat linux ( dualboot ) but could be nice to dedicate the rx6800xt to handle VR and the nv710 to handle the desktop
Add images
