der8auer had an interesting vid on a 70€ ali expresss kit that shipped from spain. I mean I’d probably not put it in a 3000€ pc but for having fun with a cheaper build it looked absolutely useable.
I have not done it myself, just read about it a couple hours ago:
Reddit’s patch for Cyberpunk 2077 yields double-digit performance gains on AMD CPUs (techspot.com)
Are there any AIO cards yet for the 3090?
I have a “build” set for an all aquacomputing cooling solution ready to order… but as you said it wont be cheap to go that way
Cool, to be fair though, I was running at 60fps nicely until I decided to up some of the settings, like dlss quality.
I have almost all up to max on UWHQD and get a bit over 30FPS with my 2080TI - its looking awsome and my GPU doesnt get to rest ;-).
Did you try VooDooDE’s VR Video for Cyberpunk (VorpX) ?
just read the article and I was questioning if it would help the 5950x because it had plenty of physical cores and I’m not sure if i wouldn’t prefer using them rather than starting to use the smt threads when I got to this part “The 16-core R9 5950X actually decreased in performance when the fix was applied” Soo, i probably won’t be using it
I’ve not tried VorpX or seen Thomas’ video on it yet but I will get there eventually.
Oh damn, sorry! Did not read that far, I had two articles in the news app and just flew over that one. Seemed more thorough, so I thought I post you that one, sorry for misleading!
don’t worry, it’s not the CPU that limits my FPS
History says this would be the performance of a 3080Ti
Looks good but unreachable .
I’ve always expected the 3080ti to be an 3090 with a bit less ram, and the super to be a 3080 with more ram, both with slight compute adjustment, probably set at msrps around 1200-1300 and 900-1000. at least that’s what I’d expect to be logical.
Kindly tell me a thing, a custom water cooling for cpu and gpu, how much time the coolant inside pipes last before the user should refill the container ?
I’ve been using the same coolant for 4 years on my old build without issues. It’s a transparent premix from ekwb but they don’t carry the same fluid anymore.
I doubt you’d have any reason to replace any transparent coolantl for reasons other than to change color in any reasonable timeframe.
Distilled waster with a kill-coil or biocide should also last pretty much forever.
You may need to top it up with a bit of distilled water if you’re experiencing a lot of evaporation though.
Opaque fluids is another thing entirely though and while they’re looking stunning they’re not recommended for any duration outside short term show offiness.
I’m not a technical guy or anything all I did was put my 3090fe into my Alienware Area 51 R2 and I can now play Skyrim VR with 402 mods with no problem. I was using a 2080 super and couldn’t handle the load but it only had eight gigabytes vram while my 3090fe is running o between 65 and 71 degrees Centigrade I’m pushing from 12 to 15 gigabytes of vramstrong text plus 13 GB of memory out of my regular Ram
I personally detest the “Super” nomenclature.
It’s nonsense and confusing and it only started because nVidia had more 20xx stock than they knew what to do with , because they gambled on miners.
I hope never to hear the term super again. As it sounds dumb.
The only company who should use “Super” is Nintendo.
i do not disagree, but it is what it is.
Wake me when something official gets announced and when there is even a glimmer of actual stock available.
