RTX 2080 Ti and SteamVR SuperSampling recommendation
Comparing the perf benchmark results to my 1080 Ti, I would say they seem alright. What however seems to be not alright is the render target resolution recommended by the driver.
This is huge. I do not know if it is only 8K thing or new PiTool thing since I do not have either, but I would ask @PimaxVR why (at assumingly PiTool set to 1.0) the headset needs so much of supersampling. Is it Large FOV?
Yes, large FOV and parallel projection set off in Pitool. It seems that the Vrcompositor.txt file does not update properly to every change. This recommented target resolution is for parallel projection on.
