Robo Recall Head movements are delayed in the game transferred
Robo Recall
I have with my pimax the problem that the head movement in this game is delayed … where can this be?
many thanks for the help
You playing the game from pitools or revive or roborevive?
Pitool and Revive :thinking::man_shrugging:
Is it just Robo Recall with Revive?
No, also other oculus games. I have reinstalled my PC. I’ll test it again. Maybe it works now. Other people play this game on the internet. And it works. So it has to work for me too.
On pimax? Something someone mentioned here if you can get oculus games to run through pitool no PP required on ones/some that have Steam versions.
Make sure Revive isn’t running on the task bar. Also, I used to run pixel density above 1 in my Rift and had trouble with Robo crashing because I had it set to 1.8 in the game settings. Once I set it back to 1 it runs great. Had to make sure my some of my other Oculus games were set to 1 as well for the same reason.
