Hi guys ,In rfactor2 i have a problem with
Stereo Image. I have uncheched reproyection with no result. Other game work well. I use pitool .95. any ideas?
Which headset did you receive?
Might be an issue with Rfactor2 if other games are okay.
I received a pimax 5k plus
Congrats!
@anon74848233 please add to earlybackers.
@industria do you have experience with Rfactor2?
Yes, i have use It with vive pro and rift with no prob
I read on reddit comment of 5k owners that run rfactor2 with no prob
But with pitool .91…
Maybe i can go back to .91…
If you have stereo problem you may need parallel projections.
I try with PP activate and deactivated, no change
Did you restart steam vr and pitool after switching pp on
No, thanks for suggestion. Tomorrow ill try and let you know the result
restarting pitool and steam VR solved the problem. Thanks
No problem thats what forums,are for glad it worked
