I just got my headset today and I am trying to figure out why its not being recognized by pitool.
I have the display port connected to 1 of my only 2 ports on the motherboard( my GTX 1070 doesn’t have one) and it keep getting an error 10600. what happens is when I plug in the usb, the headset display turns on then off.
does it have to be connected straight to the graphics card?
With being a 10series card believe it should have a dp. If you haven’t will maybe need to run Nvidia firnware bios update to enable Dp 1.4 features/functions.
correct, thats the one I just downloaded.
my pitool version I downloaded today is V1.0.1.132
I am currently downloading Nvidia 430.86
all cables seem to be firmly in place
The light greenish blue ports are supposed to be your 3.1 ports.
Ensure motherboard bios & drivers installed from Asus site.
Some Users had to remove vid cable from helmet & replug. If nothing works may need to file a ticket. If you have another computer to test on is a good option as well.
I was just typing that and pitool is now in room setup. THANK YOU SO MUCH! I can’t remember if you’ve seen my previous posts from a few days ago when i didn’t know when i was getting my headset, i was very excited nervous, but sorry about that. I CANNOT WAIT TO PLAY NOW!
Awesome congrats. Just keep in mind if you don’t have Lighthouses you need to complete Room setup after clicking LH tracking under hmd. Click through til you can manually enter height.
