my piplay menu is transparent which makes it hard to see at times. Why is it transparent
Hi, did you mean the pop-up windows or all Piplay interface? Please take a screenshot about this issue, thanks.
the piplay interface
Hi, thanks. I added this issue to our bug system and will reply you tomorrow.
Edit: We will formally fix it in the further Piplay version.
We are now a year later and i am having the same exact issue.
On piplay 3.0.0.85 even the installer is having transparency issues
I have to put a black image under it just to see whats going on, and whats worse is that the transparency glitch the hell out if theres a dialog on top of it as shown here.
Hi, I am having the same problem with the PiPlay and PiTool menu, where I am actually completely unable to setup my 4k headset (HMD) because the menu is graphically corrupted.
On the image below I pulled up the pop-up menu to calibrate 4k headset, but the pop-up menu is completely unreadable!
Help please.
