[Resolved]m another customer that cannot use pimax mode
I have tried contacting skype support to no avail.
I have had this Pimax 4k for less than a week, but i am unable to get it working properly.
using pimax mode, the PI windows display doe snot appear in windows device manager. In the windows screen resolution there is no secondary screen?
If i switch to video mode then the pimax appears as a secondary screen in screen resolution and appears in device manager.
I have unplugged usb and hdmi and reinserted… detects it for a second then it dissapears.
the led on the pimax when in pimax mode is BLUE
the led in video mode is also BLUE - but i get a KODI error when using it… details below:
Problem signature:
Problem Event Name: APPCRASH
Application Name: Kodi.exe
Application Version: 16.9.801.0
Application Timestamp: 58510911
Fault Module Name: ntdll.dll
Fault Module Version: 6.1.7601.23569
Fault Module Timestamp: 57f7bb79
Exception Code: c0000005
Exception Offset: 0004eb83
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 5129
Additional Information 1: de93
Additional Information 2: de931ea82082c305d3eaae307d749651
Additional Information 3: 0b04
Additional Information 4: 0b04a6eb0f5aa85d12ecef65d748e100
Read our privacy statement online:
Windows 7 Privacy Statement
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
I do not have Oculus installed as i only want to play steamvr
i have tried uninstalling and reinstalling nvidia drivers - had no effect.
the specs of my pc are as follows.
64Bit Win 7 Home Prem with SP1
8GB DDR3
I7-4790 @3.60GHz
Nvidia GTX 1060 6GB
please help… vr headset seems good if i can get the thing going properly?!
regards
Eno
What you describe about Device Manager and secondary screen seems correct. When you start Piplay what message do you get on your screen? Is it “Where is my Pimax?” or does it search and find your HMD.
Have you downloaded Steam and Steam VR?
yes i have downloaded steam and steam vr.
steamvr can see a HMD.
piplay can also find the pimax device.
the pimax headset has a blue LED. but on launching any game in steamvr it is shown on the monitor, but not in the headset and the LED remains BLUE (does not go to GREEN).
if i look in my screen resolution page i would of expected to see an additional screen referring to the PI screen - this is not appearing?
i have just tried reinstalling PiPlay a few mins ago… this also has had no effect?
As im on Win7, i was wondering if i need to reinstall DirectX somehow, but i think DirectX is embedded in Win7 and its not easy to reinstall??
In PiMax mode you will not see the hmd in display manager (this uses what is called Direct Mode)
What version of PiPlay are you using?
If your using 1.2.5x
Launch PiPlay
2) Choose PiMax mode
3) Launch SteamVR from PiPlay
SteamVR should launch on desktop with Hmd icon green.
In Pimax hmd you should see steamvr enviroment
Pimax will show in display properties when in video mode.
thanks Heliosurge
i will reply to each of your steps…
If your using 1.2.5x - i am using 1.2.57
Launch PiPlay - Done!
2) Choose PiMax mode - Done!
3) Launch SteamVR from PiPlay - Done!
SteamVR should launch on desktop with Hmd icon green. - Steam VR starts but HMD LED stays BLUE
In Pimax hmd you should see steamvr enviroment - Inside HMD screen is still Black. no screen or Logo
Pimax will show in display properties when in video mode. - This happens but i get a Kodi error (see earlier post)
let me know if you want me to test anything else?
I feel i should mention that i have Nvidia surround enabled across 3x24inch monitors - giving me a resolution of 5760x1080.
I have already tried disabling the 3 screens and made them 3 single screens (1920x1080 each screen) and then tried what you suggested with the same result… LED stays BLUE when i click on SteamVR - but for clarity i thought i had better mention it just in case.
thanks
Hmm might need support with Teamview @PIMAX-Support.
I beleive light should be green. If you click on the gear you can find debug which may provide more info.
Try disconnecting all monitors except 1 plus the Pimax. Make sure you reboot.
From what i have read about other vr headsets also ensure pimax is using a native hdmi port.
Launch piplay as admin.
@Heliosurge Thanks, friend, we are communicating at present: )
i am talking with Support on skype right now… thanks :slight_smile:
Your both welcome. @PIMAX-Support & @Enopho.
@Enopho while i haven’t used skype support this one aspect that makes this company top notch.
thanks Heliosurge, they have been very attentive, unfortunately my issue may not be software related but hardware problem… item has only been used 3 hours and owned less than a week. went crazy after a single reboot after installation of piplay. no idea whats wrong but to be fair, the support guy has been trying lots of things with teamviewer session
i just cant believe this as i have been waiting for gearbest to deliver this since 26Mar! and they messed my order up 2 times prior and costing me over $50 in international fees before finally sending it out.
sigh…
Sorry to hear on both. I had mine expressed through DHL & had to pay an extra $25 Canadian for customs due to it passing through the USA; wasn’t expecting the added cost but the USA is known for wanting to make money on everything.
I am confident though that our Pimax team will get you fixed up just be patient. Waiting always sucks. :wink:
Thanks Heliosurge,
do you know why the 4k would give a bit of distortion when looking around? a bit like this Pimax Distortion PC Screen (same as HMD) - YouTube
i have the same issue in Elite Dangerous when looking around the cockpit. the front console appears to bend as if the screen is warping around while i pan past it? I have checked my IPD and set it correctly. i have been tweaking the game graphics and thought it was a FOV setting but the FOV settings in game do not seem to have an effect on a HMD… only monitors.
it makes me lose immersion when it happens…
additionally there are some blurryness around the edges of the lenses, which are annoying. im really not sure if its hardware or software related, but i get the blurryness on all sides of the lenses top, bottom and sides… the sides are the worst because the games cockpit panels are on the sides and i cant read the instruments.
There is a recent post about with correct ipd setting may correct blurriness. There are methodes on tge internet to measure. Your doctor or eye glass places could also get you the info
yea i used google to find out how to measure myself… turns out i am IPD 70. and when set it as 70 the center of the lenses are clear but the edges are blurry. thought you might know a trick to make ALL of the lenses clear :slight_smile:
One thing that might work is lightly pull the headset away from your face. I found when tight not as clear. The face foam is attached with velcro. I haven’t tried it yet but might be able to take rubber peal n stick weather seal. Then get peal & stick velcro and put in either side of weather seal. Use this as a spacer for the foam.
Also a bit of the weather seal can be used to improve comfort around nose
Might give that a go to try to fix the blurryness on the edges. any idea how to fix the gyro drift? was hoping that steamvr setup would lock it to place, but nope! in Elite Dangerous have to recenter about twice every min.
i am thinking that it is trying to find magnetic north?? maybe facing North before starting steamvr setup will help but i dont know enough about how that gyro works?
I have read others having a similar issue with gyro drift but no one seems to have a definitive answer.
Unfortunately gyro drift is normal. Tho i haven’t tried the some have used
Freetrack/opentrack
Psmove
Edtracker
To compensate or replace head tracking
