I figured it out! LED is working now. Can’t delete post so editing.
Enjoy let us know what you think.
Just have to poke me. Most edit the title & put in [Resolved] Title intact.
Posting your solution can also help others whom run into a similar issue.
Congrats & enjoy!
Which headset dud you receive?
@anon74848233 please add to earlybackers
unit is 5k+,
Make sure you look at the picture diagram and plug the power adapter into the port on the Display Port Spliter NOT into the headphone jack on the unit itself. The holes are the same size and I didn’t realize until I had literally checked everything else.
Oh dayum, hope audio is ok!?!
Well that’s a new one. But on the good you found the headphone jack. Congrats share your impressions once you give it a good run.
Need any help the community here is a great resource.
Should be good as outside power jack is just ground & headset wasn’t fully powered.
Some may disagree with no wrong hole.
So you really thiught the power lead plugged into the hmd giving you about a metre movement lol,im sure no one else will make this mistake.
