Hello guys,
In short…, my status with my 5K+ received yesterday and my doubts/questions:
Once Last PiTool version downloaded and installed my 5K+ immediately start up and automatically update the firmware version.
Than, looking inside the HMD I’ve seen a rocky environment with the Pimax logo showing the IPD scale of values adjustable by moving the wheel. So I could adjust it for the best.
At present I’m still waiting for the Pimax base station and controllers than I could not go on to complete the setup.
So, I’ve closed the PiTool panel and turned off the HMD.
Restarting the PC and turning on for the 2nd time the HMD, I do not see the rocky enviroment with the Pimax logo anymore.
PiTool panel on the PC show me (see the picture 1) but looking inside the 5K+ nothing appear and not even scrolling the wheel to adjust the IPD I can see the Pimax logo with the scale value as the first time.
Using the volume buttons on the HMD, nothing change looking inside but a little volume bar appears on the PC screen. Please note that the same thing does not happen adjusting the IPD.
What does it means? Am I’m doing something wrong or what else?
Moreover, keeping it on without doing nothing for an hour or so the screen has gone from a uniform light blu color to what You see in the picture 2 (artefact???)
This is my first HMD VR and I really don’t know how to proceed at least to understand if it’s normal or not.
Thank-you very much in advance for any possible advice to help me see if the HMD has some kind of problems or how can I test it in the right way.
