Hello i am playing the amazing praydogs resident evil vr mods.
I am glad we have the 60hz option on the pimax i need that with resident evil 8 and 7.
For resident evil i need to put the steam vr sampling on 80% and set the pimax on 60 hz.
i use normal field off view.For resident evil 7 i can set the steam vr sampling on 100%
Its a pitty that the game is shimmery,but what a blast it is…
What are your settings?
Game crashes on start for me, have gone back to steamvr.
also: 4090 eats this game up can hit native resolutions ultra everything at normal FOV , 3090 I had to play small fov with FSR upscaling with low-medium graphics/lighting/effects
I’ve now also installed RE7 and plan to play it. For what are the FOV options in the ingame menu and which options should be choosed with a normal or large FOV? I do not realy see a difference, when changing them, but I have slight feeling of “warping”, when I turn my head. As if the picture given to the headset is slightly smaler as the FOV in the headset.
I’m also seeing a “veil” of black pixels, when I’m ingame, that is over the fauna, ground and the car. Is that normal or can it be fixed in any way?
How Do you ever get it to work. Mine crashes as well.
How do you get it fired up.
I have the pimax crystal with a 3900XT 4080 gpu. so should not be a problem. Not sure what I am doing wrong.
@john2910 Thank s for the reply. PLease tell me the steps you did to get it up and running and did you use Steam or opencomposite. I feel like im missing something.
Hello there i did use steam vr,and did use the settings i posted.
But i cant remember exact and i cant test it anymore because i dont have a pimax anymore at the moment because off some problems i had to sell them…Otherwise i would have helped you,sorry
