As I understand it, the whole point of OpenXR is so that the platform doesn’t need to care if the hardware is using inside-out/outside-in, lasers, cameras, sonar or whatever.
MS would get the coordinates and orientation already calculated for them.
It is up to Valve or Pimax to make the driver interface for OpenXR ( device layer )
Microsoft then “only” needs to make their platform recognise the OpenXR api ( aplication interface )
EDIT: actually, MS might need to also make the API for the device layer, but this would need to be done one time and should then support all devices that support openXR
Read the link. Openxr is just an api so programmers can use it to have their aps used on any platform without the need to have to use a variety of different apis to adapt the program from 1 platform to another.
It’s not making Oculus Home compatiable with third party headsets etc.
Now MS MR headsets are being able to be used in steam. However when I googled Windows vr with vive & such. No articles saying ms is giving vive acs to windows vr (yet).
It makes sense for Valve to accept MS MR headsets as Valve’s vr platform is not closed to headsets.
With the OpenXR being from the folks behind vulkan. Vulkan is cross platform graphics library api. Using it makes it easier to create cross platform games but doesn’t ensure a game will be available on more than one platform.
@Sjef as a programmer can likely give better details. But the link even shows it.
Yep if Oculus & MS want to support other headsets is the key.
Like Vulkan it is meant to be an open standard so content developers don’t need to learn specifics of each platforms hardware/software environments to create content.
Until MS & Oculus announce they are supporting other headset solutions like Valve has. To use these 2 platforms will require a workaround of sorts.
Now I can see possibly ms might before Oculus does. But I am sure atm MS is likely getting license fees for official MS MR supported headsets.
Actually windows MR is just 3d launcher like other said. but pixma have 8k ,means that we can create 8 1080 screen around us at the same time all running full windows mode…instead of stuck in “widget” only.
