Request: Proper hotkeys for Pitool IPD Offset and vertical offset for use with lineup
Hello
Currently to get close to correct view with the Pimax line if you dont have controllers is to endure eyestrain due to issues with factory calibration. If you have controllers you can line things up to some extent but its extremely fiddly and if the tracking for some reason shifts you pretty much have to start over. Even after it still needs tweaking.
Now the issue with for example the Vive wands is that you can line them up vertically then horizontal but it wont be quite correct (its extremely hard due to distortions and so on to get this spot on). You can do either or but to get a correct view you need to align at 45 degree too. Once all orientations match you are in the correct spot. Honestly though you could probably only do it at 45 and the rest would match but feel free to correct me on that.
Here’s what it generally looks like when its a bit off.
pimax controller
Now you can click on the ipd offset button and then use the arrow keys but its extremely tedious and hard to line up in all orientations when you need to take your mask up, find it, then it will pop to another value and you have to get back and so on.
What you need here is a toggle on checkbox to enable the hotkeys.
Right eye Up and down keys should be vertical left right should be horizontal
for the left eye use W S A D
And please do not do this in Pimax experience. It’s not usable as you have no tracked object for reference. At least not at the moment but please just dont do it only in PE. Pitool first so we can see the controllers in steamVR
We havent seen a pitool update for features in a long time so i hope you can put this in and release it asap.
Not sure what you were trying to say. Maybe your title is too short. :thinking:
