I received my pre-order today. I have an issue with white flashing/sparkling pixels on both screens.
I’ve tried to open a ticket but the support link isn’t working.
I also have awfully bad warping at the edges of my FOV. I am currently testing without lighthouses or positional tracking. Is the warping worse without positional tracking?
The pitool link is also not available for new customers!
I installed the latest beta as I will require brainwarp (smart smoothing) for my use case. I found a link to a copy on some guys google drive.
I’ve checked the cable is seated and also confirmed my IPD. The warping I’m seeing can’t be normal or nobody would be using these headsets. It’s even bad on the narrow FOV setting. Can someone confirm the best firmware and pitool version to be using and if the warping is worse without lighthouse trackers?
I was due to buy a second hand vive in a few hours but if this is what I’ve to look forward to I don’t think I’ll bother.
I’ve checked many other threads. I seem to have an issue that many others are experiencing. The sparkling white pixels have been reported by many other people.
@anon74848233@Pimax-Support could someone contact me regarding this issue. I can not access the support section of your website to open a ticket.
Thanks @Sean.Huang. I have sent you a video clip of the pixel sparkle issue.
I have spent some time adjusting the fit of the headset and have eliminated the vast majority of the distortion I was seeing. Unfortunately, the position which removes the distortion requires the bottom of the headset to move completely off my cheekbones. Currently I can position it correctly with loose side straps but I will need additional padding to ensure the headset remains secure on my head.
No idea. It took several attempts and I followed several different links on the forum. I couldn’t log back into it once I set it up and submitted the ticket. Try emailing Support@pimaxvr.com instead.
I am in the same boat - pixels and bottom padding.
For the padding I have cut up an old mousepad and used that and some velcro to make an additional layer on the bottom and sides. Sides helps me with HMD wobble too (narrow head?). I’ve used two mousepad layers, plus the velcro, and it works perfectly for me. Almost zero distortion.
I haven’t made a modification yet. I was going to use the foam in the box but didn’t want to do anything yet in case the unit has to be returned! I need to move the bottom out a substantial distance to remove the distortion.
But no one fixed the issue like that I think? Fiddling with the cable seems to relieve the issue for some a few hours but I think it always comes back? This definitely seems like they’ve made a change to the cable and this caused the issue in some batch.
I believe there was a couple that had luck. But agree majority seem to require a cable replacement. But still good to perform as a troubleshooting step to validate.
@Alan.sun@Sean.Huang
I am unable to reply to my support ticket. I have requested a password reset but no email was received to allow me to do so. I cannot create a new account as my email address is already associated with an existing support account.
Please confirm a replacement cable has been sent. I have already sent you a video. My address and phone number are the same as those associated with my original order.
