pi tool 1.0.1.109
red led solid
issue : disconnected diagnose 30000
i just need some quick help to fix this. sorry for bothering yall!
pi tool 1.0.1.109
red led solid
3000 says Service doesn’t start. Check Antivirus to see if it’s blocking Pilauncher, pi_servers.
I haven’t gotten my headset yet, so just based on some stuff I read on this forum: try 72Hz
This hasn’t seemed to work, alongside this for @Dr_Qrunch response i cant select the hmd or brainwarp. even after trying new display ports and usb ports, switching to wmr hmd and back it still remains turned off but its audio pass through still works, i can hear and talk through it but yet it has solid red led, ive tried turning it off and on its really odd. and the diagnose is 30000 not 3000 if that makes any difference.
Hi,can you see piservicelauncher in taskman service?
