[Replied]Issues with Oculus games - FEV/2019
So friends,
Finished Hellblade, man what a trip it was. Played for 5 hours straight and felt like 1 hour only. The bosses are incredible and it run amazing. Unforgettable last boss. AMAZING !
So next in my list is Lone Echo.
The game is working just fine, but somehow i CAN’T use the grip buttons. What i’ve tried so far:
  • Installed latest revive - Didn’t make a difference (mostly because i believe the injector Pimax uses is form their app folder, totally independent of Revive)
  • Installed advanced Settings and tried to edit the config buttons there - Didn’t make a difference
  • Tried to inject LoneEcho.exe with installed revive version - Don’t show the image on the HMD
Does anyone here knows in which version of Pitool Lone Echo played fine ? Because we could copy ONLY the “plugin” folder (C:\Program Files\Pimax\Plugin\OCSupport) and use to that specific game.
I believe either @SweViver , @mixedrealityTV or even @VoodooDE could tell this for sure or upload the plugin folder.
I also believe this applies to all games that so far appears to have become broken, like:
  • RoboRecall - Doesn’t start
  • Lucky’s Tale - Above or bellow the ground (mine is bellow, recentering don’t make a difference)
  • Edge of nowhere - Extreme pixelated, like i am running pitool at -0.5x (maybe hardcoded resolution?)
  • Chronos - Low resolution (but better than Edge of nowhere)
Thanks and GO PLAY HELLBLADE RIGHT NOW. WHAT A MASTER PIECE.
SweViver has it running here, I am too lazy to find out the PiTool version though.
Hmm.
He was running at Pitool .74.
I will compare the internal injector versions and try.
Later, i will post a summary.
And yes, i’m back with my report:
Installed pitool .74 and here what happened:
  • Lucky’s Tale - Working flawlessly
  • Robotrecall - Still hanging at the startup
  • Lone echo - Working very good, but still can’t pass the grip button part
Gone back to .103 and:
  • Lucky’s Tale - Wrong camera height, other than that working just fine
So it really is something in the Pitool “emulator”. I hope it gets fixed.
The recent SteamVR version could be causing the problem.
https://community.openmr.ai/t/oculus-game-starts-with-screen-too-high-in-the-hmds-view-dirt-rally/14715/9
@Douglaster
Tks for your feedback, we will check it.
I don´t believe this is the case, mainly because you run the game directly from Pitool.
  • Lucky´s Tale working just fine without Lighthouse tracking.
Just recenter and play.
Can I ask what setting you uses to play hellblade and how did it look/perform? Cheers
Sure
Pi tool on 1.0 - normal fov - anything above this will make the game bugged and the quality increase isn’t noticable
Brain warp at 64fps
Parallels projections on
In game quality on medium and it’s internal super sampling at 100
With this I played from start to finish without issues.
Very good game
