My headset worked for one-week. I haven’t been able to get the headset to connect at all. I’ve done the following to troubleshoot the issue.
- Checked cables, verified they are snug
- Removed any extension cables between the Pimax and my PC
- Cleanly removed all Pimax software, NVIDIA software, and re-installed. This also means I went into the AppData/ directories and forcefully deleted any Pimax references.
- Switched out various USB cards (Although the USB isn’t the issue, its a dP issue)
My video card is: EVGA GeForce GTX 1080 Ti FTW3 (11G-P4-6696-KR)
I have one main monitor connected via dP and two open dP’s and an HDMI.
Oculus Rift and HTC Vive work fine on my system. Pimax 5k+, the headset seems to be the only problem, giving me the error of Error 10600 HDMI/DP Disconnected. I’ve taken my system apart and removed anything extra, the device chain doesn’t show any issues. I’ve restarted the Pimax service, several times, verified my GPU was current. I’m running 419.35 NVIDIA drivers.
Anxiously waiting for a resolution here so I can use the headset. I was able to use it for 1-week and then I rebooted my system and it broke. I’m running Pimax Tool 1.0.1.11 Beta now (upgraded in case it would resolve my issue) but it hasn’t.
My complete system specs are:
- ASUS ROG LGA1151 DDR4 DP HDMI M.2 Z370 ATX Motherboard with onboard Gigabit LAN and USB 3.1 (Maximus X Hero)
- Intel BX80684I78700K 8th Gen Core i7-8700K Processor
- Rosewill PHOTON Series 1200W Full Modular Gaming Power Supply, 80 PLUS Gold Certified, Single +12V Rail, Intel 4th Gen
- SAMSUNG 960 EVO M.2 500GB NVMe PCI-Express 3.0 x4 Internal Solid State Drive (SSD) MZ-V6E500BW
- 32GB RAM G.SKILL TridentZ RGB Series 16GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 4133 (PC4 33000) Desktop Memory Model
- Corsair Hydro Series H150i PRO RGB 360mm Radiator Triple 120mm ML Series PWM Fans Advanced RGB Lighting Liquid CPU Cooler (CW-9060031-WW)
- EVGA GeForce GTX 1080 Ti FTW3 GAMING, 11GB GDDR5X, iCX Technology - 9 Thermal Sensors & RGB LED G/P/M, 3x Async Fan Control, (11G-P4-6696-KR)
- StarTech USB 3.1 PCI-e Card – 4 Port – 4X USB-A with Two 10Gbps Dedicated Channels – Expansion Card – USB 3.1 Card (Pimax is connected to this card)
- (NOT CONNECTED) Inateck Superspeed 4 Ports PCI-E to USB 3.0 Expansion Card - Interface USB 3.0 4-Port Express Card Desktop with 15 Pin SATA Power Connector, [ Include with A 4pin to 2x15pin Cable + A 15pin to 2x 15pin SATA Y-Cable ] (KT4001)
