I have opened a ticket with support but I want to get some visibility on this. (Kickstarter backer)
My headset is showing code 10600, stating it is disconnected. I have not even been able to run an initial setup, and this problem was experienced on a 2nd PC I tested with.
I have tried every USB port (2.0 and 3.0)
Powered USB hub
Updated GPU, BIOS, and USB drivers,
Rebooted over and over again,
Flashed P2.1.255.181, and even P2.DFU in C:\Program Files\Pimax\Runtime\dfudriver,
Made sure I was on DP 1.4,
Reinstalled PiTool (purged appdata contents on uninstallation as well)
PiPlay has never been installed on either of my machines.
No success on any of it. It just switches between 10500 and 10600. I have removed and reseated the custom HMD cable The HMD light is solid red and no light has come out of the displays.
At this point I am under the impression that the cable is bad.
My specs are as follows:
GTX 1080
16GB RAM
i5-3570k OC’d at 4.5 GHz
Asrock h77 Extreme4 mobo
Hi King, I don’t own a headset but I’ve had the opportunity to test one over the last few days. I was getting the same error, I found turning the headset off by it’s power button and then turning it back on allowed it to connect. I also tried just disconnecting the power lead but it didn’t work. Try what I said, I think you’ll find it works. Good luck
I’m sorry to hear of your less than excellent experience! I was able to get support to connect to my PCs last night and test. Unfortunately they deemed the unit defective and I have to ship it back…
Thanks for wishing me good luck. I’m gonna need it
Just keeping everyone updated…I was asked to send my device to a warehouse in San Jose, CA. UPS just notified me that no one was around to receive the package. They will try again tomorrow…
