Replacement face foam
Hi, can anyone provide me with a link to a thin Face foam pad ? I see some vive ones but im not sure if they will fit. I want to take off the original face foam mask and replace it with another thinner one. I find if i remove the face foam altogether i do not get any overlap.
Kind regards.
The cheap ebay ones for the Vive will fit
Im going with this but its a bit expensive. i need the 6mm but i was hoping good people might have a link for cheaper ones.
@PMXskciVR i believe found $5 ones
I don’t like how the fake leather folds on some of these pads (like the one you linked). Gonna leave more marks than necessary.
can you link the 5 dollar one please
https://community.openmr.ai/t/5-facepad-for-pimax-5k-from-aliexpress/17639?u=heliosurge
Woah, tempted… Struggling to decide wether to get the 18mm one or the 16mm one, based on the picture, the latter looks to be tailored for Pimax HMD?
I had also ordered 18mm version, but that one does not cover the nose are and was a bit too thick for my face. It is very affordable so would not hurt to order both version just in case as I did.
Thanks for the suggestions however i need the foam pad to be as thin as possible… As much as i turn the ipd dial in either direction i get the binocular overlap from the physical lenses. its kind of like an oval shape in my central vision. If i remove facemask altogether and place lenses as close as i can to my eyes i do not see that overlap and its near perfect,. So thats why unfortunately i need 6mm or under face mask
There is also a 7mm version with $3.8 at the link I provided.
Hi I tried a Vive 6mm from vr cover and although not very comfy the picture improved and it reduced Sde for me.
Can you provide the link please? i cant find it.
Click on his profile it’s under top links/topics on his profile.
https://s.click.aliexpress.com/e/ccqGuDYc
Pimax need to seriously get themselves into shape here. My 5k+ is completely unusable for me the way it shipped. Had I been a purchaser instead of backer and hadn’t spent the last year + on this forum the first thing I would have done is boxed it back up and sent it back.
Now by adding a $5 (one off purchase by me) face foam it’s totally useable. It’s a million times better and although I’m still having my problems I’m now inclined to persevere and see what this hmd can do.
Pimax can get on AliExpress and do a commercial bulk buy and ship those pads much cheaper now. Or could make the ones they promised over a year ago.
Seriously to turn an unusable $1k item into a usable and possibly really good $1k item for a few clicks of a staff members time and a couple of dollars per order… and still that’s too much for pimax to handle. It’s a great case study for commerce students in what not to do.
Can’t purchase from AliExpress by PayPal?! I’ve never used them so I’m reluctant to hand over credit card details.
I made hundreds and hundreds of purchases from aliexpress, I can honestly say it is safe.
It’s like the Chinese version of Amazon.
What one did you buy ? can you link it please ?
