Is this a bug. Why is there a red dot on my Pitool when I have the latest version? Check out the image.
https://drive.google.com/file/d/1EnNaNY25xtOUE37zKhgyaMM36Ihekyk-/view?usp=sharing
It’s because it thinks it’s not the latest version.
Just ignore it…
Yes thats because the current version compatible with PE are not official and have a different version number, so it thinks its old. Just ignore that for now. Will be solved once we go public beta
Just FYI, tested build .34 with PiTool 1.0.1.264 and it seems to be working correctly. At lease I didn’t see any errors or glitches during my testing.
Thanks man, there are still bugs for sure, but its getting better I guess
