get the OpenVR plugin for OBS, then add the Plugin as a Source, then right click on OpenVR Capture - go to Properties and crop the image as shown below or play around with the values as you like.
I’m using an i7-8700k, 2080ti, and 32gb ram. I’d hope that’d be enough to stream a VR game!
Though it’s sad the recommended resolutions are to use another 3rd party program to capture when Geforce Experience Shadowplay already does this, and I feel like the issue should be fixed from Pitool.
I do not want to have to edit and crop my own capture - Vive, Index, and the rest record just fine on their own. If this is a result of the wider FOV (even occurs on ‘small’ fov setting on Pimax) then I’m sure a more premium headset down the line will figure out how to properly capture gameplay without the use of a 3rd party program.
Pitool, SteamVR, OBS…that’s all too much. Vive just needed SteamVR and captured fine.
