Anyone have a suggestion for an inexpensive racing wheel stand? I’ve had to postpone getting into iRacing because the wheel stand I bought is a POS and won’t lock the Steering wheel support post in place either forward and back or on the twisting plane. So as I play, I wind up with my pedals getting farther away (did I mention the structure doesn’t fit the pedal set either?) and the wheel winds up in my lap twisted to the max angle my chubby body will permit. I bought it on Amazon… I will be returning it. if you’re looking for a racing wheel stand AVOID this one:
Mophorn Gaming Steering Wheel Stand 360 Degree Stepless, Steering Wheel Stand Adjustable Wheel Stand, Shifter Mount Stand fit for Logitech G29/G920/G25/G27,Wheel Pedals Not Included
@SweViver seems to like this one, but it’s ~$250, so I’m not sure that’s “inexpensive”. Hopefully, he will post here and let us know how well it’s held up, since he got it.
@Finn I bought the GT Omega from Amazon a month or so back and have to say I’m very pleased with the qualiity and functionality. It was like 160 bucks, solid metal construction.
OK I was looking at that one! Amazon is sold out right now but maybe I can find it somewhere else. If not I think I’ll just wait until it’s available. It looks like a good choice- thanks very much!
I think you’re right. I’m trying to send the old one back, but the retailer insists on video that proves the unit is defective. What a pain. I think I can make it work by just drilling a couple holes in the base bar where it joins the long side bars and dropping in a hard rubber bolt of some sort.
I may do that. Definitely don’t let anyone you like buy this crap.
