The HMD is tracking along with one controller. The other is connected but not showing inside HMD. Can’t find a fix yet.
Congrats added earlybackers to your post.
@anon74848233 please add to earlybackers.
Also try a search in google as this issue might also have been experienced by vive owners.
You haven’t seen anyone else have this problem? I’ve had my Vive and Vive Pro plugged and have never seen this issue. I guess I’ll reinstall Pitool
Try to restart PiServeceLauncer in service tab of task manager.
Try another usb port.
Try to remove openvr.settinng in openvr folder.
Tried everything except i can’t find openvr.setting. openvr-Advancedsetting folder is there under openvr but not openve.setting
Any other ideas? it is weird that steamvr isn’t recognizing the hmd. It detects usb but gives me the 208 error.
The HMD and controllers are tracking but I cant bring up Steam menu or anything. Controllers aren’t tracking very well either,
Steamvr shows bluetooth services not available… Is this what could be causing it?
Try turning off safe mode. That’s what fixed it for me and get PiTools to take over SteamVR
How did u get safemode to stay off? It keeps coming back
Which headset did you receive?
Finally got it working!! Steam and desktop don’t show up in Steam menu but I’ll figure it out.
How did you get it to work incase someone else runs into this problem?
I’m not sure. The safemode might have had something to do with it but it still asks me to disable or dismiss it even after I disable it. I reboot it again and it works.
Sorry wrong file
openvrpaths.vrpath
It is in openvr folder
More solution.
Yesterday I take my pc to my friend home, I have to do a lot of thing to make it work.
