Would you like to see another Kickstarter after consumer release later in the year, or in the net couple years if Pimax needs to raise more funding to make an improved 8k and to improve the screen used in the 8KX so itt’s not using the same pentile display that’s used in the 8K?
Since adequate screens are only now just becoming available, this could happen in the near future since Pimax has already opened a factory and has components for the 8k and 5k+, R&D would be much quicker…Screens just need to be sourced and tested.
Backers weren’t entitled to receive the 5k+, so the 8k+ shouldn’t be given to backers or exchanged since there were no better screens at the time of the kickstarter for the 8k. But since the 5k+ was released, that doesn’t mean Pimax shouldn’t look towards releasing the 8K+ and 8KX when screens become available, on the contrary I think they should.
Now’s a good time to be talking about it since theres no news about the 8KX yet or what specs it will have.
I suggest upgrading a screen to 4k full rgb strip LCD like the 5k+ had, but for the 8k+, to use that same LCD on the 8KX instead of the 8K’s screen, upscaler upgrade for the 8K in the 8k+ and to offer OLED versions of the 4k screens if they become available in the future. I propose this screen be used at the far left of the column at the bottom of the page https://www.boe.com/en/product/xsqj/xnxs/vr-ar the 4k full rgb lTPS LCD at 75hz (overclocked to 80 or 90hz) or a 4k oled 5" full rgb stripe screen if it becomes available in the next year or two.**
Kickstarter goals for the 8K+
8K+ - Better upscaler, better full rgb stripe lcd or oled screen
8KX - Better cable (so only 1 is requred), Different screen than the pentile screen used in the 8k (same as 8k+ screen, full rgb LCD).
8K+ Pro/BE (upscaled 4k oled)- If 4k full rgb stripe oled exists in 5" in 2019 or 2020.
8KX Pro/BE (native 4k oled) - If 4k full rgb stripe oled exists in 5" in 2019 or 2020.
Would you back a kickstarter later in the year or in the next couple of years, or support a consumer release of the above kickstarter goals? Would you prefer a consumer release? or would you rather pimax makes no more headsets?
- I’d like to see a consumer release of 8K+ and 8KX and OLED BE models first, or a Kickstarter if Pimax needs funding for it…
- I would back another kickstarter, if not, I don’t mind a consumer release of those models happening.
- Kickstarter is okay. No further consumer models.
- No kickstarter, no further consumer models in the future.
0 voters
What type of naming would you like to see for a new headset and the oled screen variants of it?
- 8K+ Pro
- 8K+ BE / 8KX BE
- New name for the 8K+ and its oled version.
0 voters
