Please help with controllers?
Hey there. So I am going to be buying a Pimax 4k without the controllers, so I was wondering where can I buy some and do any VR controllers work on Pimax 4k? (like, oculus rift controllers, etc.)
If you could also suggest some good ones, I would be thankful!
There are a variety of controllers out there
Razer Hydra (hard to find for good price)
Psmove (Drvr4vr good frontend)
Do a search on motion controllers in forum there is a recent topic on others
NOLOVR you can try.
The Razer Hydra is also a good one i think.
Would the Samsung gear vr controllers work?
Also, is my pc specs good enough?
Thanks!
No idea on gearvr controllers. As for pc specs? Can’t say no info on it.
Ooh ok, thanks anyways!
If you can post your system specs can help you on that
AMD Athlon™ II X3 450 Processor, 3200 Mhz, 3 Core(s), 3 Logical Processors
8gb RAM
Windows 10 64 bit
VRAM 2029 MB
AMD Radeon ™ R9 200 series
Tell me if I missed anything ,thanks!
Gear vr controllers is not suitable for pimax.
I think you pc specs can try,but I prefer nvidia and my pc
GTX 1070
8gd RAM
windows 10
Judging by your vram looksclike an r9 285?
If so will likely need an upgrade on gpu. Download SteamVR Performance test.
Oh, alright, thanks!
So just one more question, do you think you can give me a link to some controller for the pimax?
I’ve been trying to find one on amazon, eBay and some other sites, but I can’t seem to find the ones that people told me. (Aslong as it’s not over 50$)
Thank you!
Tbh honest Psmove might be the cheapest but i think its around $100 in cost.
Now Openvrinput that @Evol mentioned can likely map vr inputs somewhat.
I don’t have a 4k so I don’t know from personal experience but it seems like Nolo is the best choice. Also certainly easiest to setup. Hydra is a good choice except for the cables and getting it cheap isn’t likely. PSmove I guess would be a decent choice. However with the Hydra drivers and FreePIE you can get just about any controller working to some degree. Some examples are Wii or Xbox 360 controllers but it’s not simple to setup.
OpenVR-InputEmulator currently only supports OpenVR controllers which are Vive Wands, Vive Trackers, Oculus Touch and Razor Hydra w/Steam drivers. I use it to send input from my VR Treadmill through the Hydra drivers to the Vive/Touch controllers.
I was trying to find Nolo controllers, but I can’t find any anywhere. Could you possibly give me a link? On their official site they only sell with the VR glasses, but they are out of stock anyways.
You can send an email to Nolosupport. this is mailbox:support@nolovr.com
Alright, thank you! :smiley:
You are welcome.:grinning:
