So basically this workaround is still worse than using PP On?
The issue I think is SteamVR or the game devs. In some cases like for the valve index, they have canted displays but it just works out of the box somehow.
This PP On/off is a massive issue they need to get around.
PCar1 had an Oculus ID although I never found it offered any performance improvements in that game myself. Automo and PCars2 aren’t available at OH so do they even have Oculus ID#s or an Oculus Mode?
Thanks for posting this work around. I was wondering why I couldn’t launch American Truck Simulator with oculus mode today. I had previously setup a shortcut in PE for it to launch through Pitool but today it wouldn’t work. I thought it may have been my switch to Pitool 269 so I dropped back to 268 not realizing that the issue was also present in 268. This shortcut method worked though.
Create a txt.file and type in
(“C:\Program Files\Pimax\Plugin\OCSupport\OVR_Launcher_x64.exe” F:\Steam\steamapps\common\Project CARS 2\pCARS2.exe) Please change the game folder path according to your PC
Save the file and change it to BAT.file
You may try to open the game and run in oculus mode.
your question is directly after the post that answers it – but at least on the latest pitool versions it’s pointless , sure you dont need pp mode if you use that explanation but for some reason the frame rate does not improve. to get the same boost you’d have to pick out a very old version of pitool that still benefitted from the trick as we’ve gotten no clear feedback from the pimax team about what happened or why the oculus mode doesnt pay off anymore.
I don’t think you guys care. Parallel Projection hasn’t been working with Project Cars 2 for a few months now. Please tell your staffs to fix this shyt and make sure it work…it is very important that these games need to run at a stable frame rate to make it pleasant to the eyes. Don’t force people on parallel projection…please get your shyt together. And I only said this because it has worked before.
Also trying to play project cars tried all the work arounds but none of it works
Image is flickering even with pp on its no good
And for some reason I always end up in the middle of the car no matter if I put the hmd on my head still don’t end up in the driver seat
But youknow after spent the last 3 hours to fix al these issues I give up cause it used to work properly but for some reason it doesn’t seem to stay that way
Just stumbled upon this Oculusmethod yesterday on youtube and since it doesn´t work in the easy way since some Pimaxupdate, I tried a search here in the forum. So I came to this topic here.
I too would really appreciate it, if the Devs would make this work good again as it seemed to work in earlier versions. Maybe even a simple option to chose from in the Pimax Experience would be a dream.
