In pitool, the maximum rendering quality is 2, but up to 3 in piplay. I would appreciate it if you compare the image quality of 8k and 5k + in both settings
From what I see in the video. The configuration of the fov in small mode.
You can check operation in other larger fov.
We already have a lot of viewers with that fov.
Even Pimax 4k itself.
i think the point they are making is new pitool may have added an additional quality slider buried in menus and to check to make sure testers are on same settings or not new slider position in testing…
