The 64Hz refresh rate option in the newer pitools is disappeared. Pimax team, please bring that option back. It is very useful for sim racing games that do not require fast Hertz, but instead smooth/jitter free are more important factors, when using a non top of the line graphic card/increased supersampling.
The pimax hardware still support 64Hz. This can be seen by the fact that I can use an older pitool to switch to the 64Hz, and the refresh rate remains when I reinstall the newer version pitool. However, if I change to a different refresh rate in the newer pitool, it is not possible to change it back to 64Hz. The only way is to install the order version pitool, and change it to 64Hz, and reinstall the newer pitool. This is too troublesome and irritating.
Please, Pimax team, bring that option back. Especially when the hardware still supports that mode. All you have to do is to add the 64Hz option in the UI. And, please also add the 64Hz in the upcoming Pimax Experience if possible.
I’d really like to see a 72Hz option for my 8KX (at native res). It’s really good for watching movies, but the framerate is a bit jerky at 75Hz. That isn’t a multiple of 24Hz, which is what most cinema movies are filmed at.
100 percent agree! I wonder if Rivas10 hack for the 64hz option would allow us to add our own options like 72Hz. I have a feeling it isn’t that easy and I don’t really want to break anything trying to find out.
You are probably correct. Interestingly, I remember @mirage335 saying that there were multiple options for the 8KX refresh rate on his unit, so hopefully we will have 72Hz soon!
Seems to me like chronological order.
72Hz - first running stable before able to reach 90Hz
90Hz - kickstarter target refresh rate
64Hz - refresh rate requested by backers
120Hz - when they started experimenting with highrer resfresh rates
144Hz - the last & the max they could reach on 5k+
