Does anyone have any idea why Revive or direct from Pitool / PE don’t work now? have worked before. When I start the game it loads for some time with a back screen then comes back to steam / PE.
Works as normal here with Revive or directly with PE/Pitool. Maybe you forgot to start the Oculus software? (its required to run in the background)
Never had that running before.
Strange was thta I did not have oculus store running, have never needed that before. NMow it works so thx Martin
Hehe no problem. Yeah many times it actually starts in the background by itself, but not always. I took me a while to understand that it needs to be running
Hello,
I have Asgard Wrath and I tried to launch it using PE or Pimax Software.
The game launch with a black screen on the monitor for 5 seconds and go back to desktop again.
I am on Pimax 272 and firmware 299. Oculus Software is running.
Did I miss something ?
Thanks
It works using ReVive but performance is usually better when Oculus Games are launched directly with pimax.
For me it then was that I did not have oculus software running.
Happens all the time for me too since I don’t have Oculus set to start at boot.
