Anyone know if they’ve fixed the firmware issue?
I had a problem with flashsing screens at 90hz with the 8kx y had to reinstall again the firmware to fix the problem
I’ve used every iteration of PiTool and Firmware and eventually reverted back to 298 and PiTool 270. Its the last actually stable version for me on the 8KX @ 90Hz.
I hd to completely uninstall everything PiTool related, and used CCLeaner to removed any orphan registry entries. I then went into User Files area under local and Roaming and deleted any leftover Pimax folder.
With everything removed, I used DFU.exe to MANUALLY install the latest Firmware, and then installed the latest PiTools afterwards. Works like a charm now.
GL
